Not sure what why a motion sensor would determine house mode… can you elaborate the use case?
If it helps, I have a HD850WF and B550 Chamberlain Wifi openers along with a Vera Plus named Jarvis with this plugin.
[ol][li]When one of the openers is opened, I turn on the garage ceiling lights and hallway lights, when in NIGHT mode[/li]
[li]When one of the openers is closed, I delay 10 minutes and then turn off the garage ceiling lights, when in NIGHT mode[/li][/ol]
I use the Vera housemodes plugin with a Sunrise and Sunset scene to change house mode from night to day, day to night.
Is anyone else seeing intermittent functionality / loss of functionality with the latest version of the app? I’m probably seeing a 50% loss of use with mine and it was always rock solid. The app authenticates and checks in, but half the time the door doesn’t automatically open when I come home (and I have a geofenced scene on my phone to open it automatically that always worked until about 2-3 months ago).
I meant in dashboard => configure preset house mode => “Choose sensors to arm”, if there is a motion sensor device for the garage door, I can simply check to arm it for away or vacation house mode.
I use the Vera housemodes plugin with a Sunrise and Sunset scene to change house mode from night to day, day to night.[/quote]
I tried searching through this thread but I was unable to find what “Enhanced Status” does. I tried opening and closing the garage door with it enabled and disabled and I didn’t see any difference.
Thought I would post again to see if anyone else is having this issue.
Everything was working fine for me for an extended period. Now, the device shows that it has recently checked and authenticated, there are no errors, yet I get at least a 50% fail rate from various scenes that are either triggered off of the change of state of the door or attempt to control the door.
[quote=“oliwa, post:865, topic:180826”]I tried searching through this thread but I was unable to find what “Enhanced Status” does. I tried opening and closing the garage door with it enabled and disabled and I didn’t see any difference.
Would someone please explain?[/quote]
From a long time back I “think” it was supposed to show opened, closed, and “opening” instead of how the app shows a question mark.
Change the variables of category_num to 3 and subcategory to 5 for Garage Door. See the link below for reference. Then reload the luup engine. After the luup engine restart, it shows a garage door and status but you’ll see the variables reverted back to 7 and 0 respectively.
[quote=“tomtcom, post:867, topic:180826”][quote=“oliwa, post:865, topic:180826”]I tried searching through this thread but I was unable to find what “Enhanced Status” does. I tried opening and closing the garage door with it enabled and disabled and I didn’t see any difference.
From a long time back I “think” it was supposed to show opened, closed, and “opening” instead of how the app shows a question mark.[/quote]
Everything was working fine for me for an extended period. Now, the device shows that it has recently checked and authenticated, there are no errors, yet I get at least a 50% fail rate from various scenes that are either triggered off of the change of state of the door or attempt to control the door.[/quote]
Noticed something else a bit odd…
At 11:20 AM today, the status showed last auth at 11:16 and last check at 16:16
As of now (see times in the pic - it’s 4:31PM), last check is the same but last auth is 21:16.
What in the world is going on with these times?[/quote]
Sent from my Pixel 2 XL using Tapatalk[/quote]I didn’t change it so I assume it doesn’t matter. Did you do a manual luup reload? I actually changed mine while I wrote the op to you.
Sent from my VS995 using Tapatalk[/quote]I did a restart if the Vera plus box, and mine are showing up with a light for the icon, but still lock and unlock for the options. So not sure what’s not changing.
Sent from my Pixel 2 XL using Tapatalk[/quote]And they are showing unlocked all the time.
Plug-in still works for me. I have two Liftmaster 8500’s with My Q and I can control/monitor both. However, Vera randomly sends false positives that the 2nd door was opened which is throwing off scenes so I had to disable them (My Q doesn’t show these events, and it only happens with my 2nd door).
