Centralite Leak Sensors #3315 update issues
Hoping to get help here. I have 12 Centralite/Ezlo Leak Sensors #3315 and all are stating it needs updates. But when I do this, nothing happens. Some are reporting fine with Temps and battery levels, while others show 100% battery and no temp.
I think it needs an updated driver. Does anyone have recommendations where I can get drivers for the Centralite Leak Sensors? Really regretting buying so many of these now.
This is where I purchased it from: Centralite by Ezlo Water Sensor - Monitors Your Whole Home for Leaks - Detects Water Leaks in a Kitchen, Bathroom, Basement or Laundry Room - Zigbee - Amazon.com
Hello @hipertec
It seems that your sensors might be connected to a SmartThings hub, is that correct?
Hi @jonathanB , Yes- connected the new V3 Smartthings hub. Some sensors dont report temps either…not sure why. Any new drivers that could of fixed this?
Hello @hipertec
I will check with the team in charge and get back to you as soon as possible.
Thank you for your patience and understanding.
