My cellphone has just been stolen.
When I change my password in the vera3 setup , is that sufficient for Authomation not to work?
Thanks Cor :-s
Thanks Cor :-s
I never changed it from the vera, but I would assume it is tied with the mios servers. It should then stop working with AutHomation.
Can someone please try. Change the password in the vera setup and than check if authomation is still working?
Many thanks,
Cor
You can verify your self.
Can you login to http://cp.mios.com with the old password.
Ok , thanks,
I wasn’t sure If I ever inserted a password in the authomation app. Not possible to login with the old passsword on cp.mios.com ,so I guess it is ok now ![]()
Cor
