So, I have a few ceiling fans (8; 3 without lights) in my house that I want to add to my z-wave network (which is quite small as it is now). I see that some people opted to go with the Insteon approach using the FanLinc. I was pretty much set to go this route, but then I started wondering. Besides the benefits of:
[ol][li]Not needing a wall switch if you don’t want one, and[/li]
[li]Only taking up 1 gang if you do want wall control[/li][/ol]
Is there any benefit of going this route? I ask because for most of my fans, I have no problem ripping out the jbox and installing a bigger one to accommodate 2 switches. In some locations, actually, I’ve forgone ceiling fan lights all together by using recessed lighting instead ( back porch and living room, which make up the 3 fans). Is the fanLinc just that much better and is worth the trouble to keep the Insteon scene controller and fanLinc in sync? Have most of you done it because you’re lacking the 3 wire going to the fan (which means you can’t control the fan and light separately from the wall)?
I’m just curious and I really want to do my research before I move forward. Right now, I’m thinking I can use a leviton fan controller and a leviton dimmer (though I have to test if it will work with my LED bulbs first). I personally ran the power for most of my fans, so I made sure that even those without lights have 3 wire going to them just in case. I guess this is going to expand my options. The only daunting part is the replacing of the jboxes.
Another quick question, for those of you with FanLincs: How are they with LED bulbs? that is another concern of mine as well.
Thanks ![]()
