unfortunately when parts of my network became corrupted, i used the “remove dead node” button in UI4 which apparently, as i’ve learned is tantamount to punching myself in the crotch repeatedly.
now my trane thermostat cannot be re-paired- because the menu options only allow it to be removed, and of course that doesn’t work, even though i’ve tried to remove it using my vera two in exclude mode with the battery pack.
so i’m basically screwed- i’ve tried the hidden installer menu on the trane, i’ve tried to factory reset, i’ve tried removing it from the wall, but there’s a small battery that preserves the config, so that failed.
does anyone know of anything i can do on the trane itself or on my vera2 to try to exclude it so i can re-join it to the network?
i realized i was doing a newbie error and putting vera in exclude mode wrong. When i took my vera right up to it, pressed battery, let it get stable and then hit - , then excluded it worked (light fluttered).
