Waited for 15 min, upgrade still hasn’t fiished - as stated in the instructions power-cycled Vera - after which it suggested me to upgrade… from 541 to 565 yet again…
Tried again - the same result. WTH?
Did You get it to work?
Just tried it again - it worked.
I always facing the upgrade problem as above, and now even the 591 is out. The browser will show its done, but Vera firmware images actually not loaded at all. I used to download the firmware thru’ url provided and upgrade it in openwrt>upgrade. It always works. I just hope that MCV can provide all the respective url for download once the new firmware is being upgraded. Cause it is just an alternative for those who might not get it work thru vera download.
Rgds,
Alan
[quote=“alantang, post:4, topic:164410”]I always facing the upgrade problem as above, and now even the 591 is out. The browser will show its done, but Vera firmware images actually not loaded at all. I used to download the firmware thru’ url provided and upgrade it in openwrt>upgrade. It always works. I just hope that MCV can provide all the respective url for download once the new firmware is being upgraded. Cause it is just an alternative for those who might not get it work thru vera download.
Rgds,
Alan[/quote]
Can you tell us what browser and os are you using?
