Can't install ntp client
After upgrading to 404 I can’t install the ntp client, it was installer under 320. Here is the log from openwrt:
Downloading http://downloads.openwrt.org/snapshots/brcm-2.4/packages/Packages
Updated list of available packages in /usr/lib/ipkg/lists/snapshots
Downloading http://downloads.x-wrt.org/xwrt/kamikaze/snapshots/brcm-2.4-2.4/packages/Packages
An error ocurred, return value: 1.
Collected errors:
ipkg_download: ERROR: Command failed with return value 1: `wget --passive-ftp -q -P /tmp/ipkg-mEFp4d http://downloads.x-wrt.org/xwrt/kamikaze/snapshots/brcm-2.4-2.4/packages/Packages’
Any ideas?
Check the URL - there is no brcm-2.4-2.4 directory on the server, there is brcm-2.4 instead:
you may want to check your /etc/ipkg.conf
Ok, but then there is an error in the firmware… Because I just used the link on the openWrt pages right after upgrading to 404
Well I fixed the /etc/ipkg.conf, but still can’t install ntpclient. Tried to install it using commandline, here is the response:
root@HomeControl:~# ipkg install ntpclient
Installing ntpclient (2007_365-1) to root…
Nothing to be done
An error ocurred, return value: 28.
Collected errors:
Only have 0 available blocks on filesystem /, pkg ntpclient needs 52
Any ideas?
Looks like you are out of space.
I figured that out myself, but how can that happen? I have installled ntpclient and done an ipkg update, besids upgrading firmware (which took away the ntpclient). Thats all, so there nust be something rotten somewhere…
For me this is a big issue so here is more info:
From ssh:
root@HomeControl:/# du -s *
723 bin
0 dev
415 etc
0 home
1526 jffs
3897 lib
0 mnt
4 proc
19746 rom
0 root
85 sbin
1 sys
300 tmp
12755 usr
1 var
3356 www
and
root@HomeControl:/# df
Filesystem 1k-blocks Used Available Use% Mounted on
tmpfs 15248 324 14924 2% /tmp
/dev/mtdblock/4 1344 916 428 68% /jffs
mini_fo:/jffs 6144 6144 0 100% /
