In PLEG: My starup Lua Code is
function VOLUME_DOWN()
cmd = 'sendir,1:3,1,38000,1,1,172,172,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,21,22,64,22,64,22,64,22,64,22,1820'
sendir(cmd)
function VOLUME_UP()
cmd = 'sendir,1:3,1,38000,1,1,172,172,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,64,22,64,22,1820'
sendir(cmd)
function CHANNEL_DOWN()
cmd = 'sendir,1:3,1,38000,1,1,172,172,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,21,22,21,22,21,22,64,22,64,22,64,22,64,22,21,22,64,22,64,22,64,22,1820'
sendir(cmd)
function sendir(commandtosend)
commandtosend = commandtosend .. ',\r'
local socket = require("socket")
c = assert(socket.connect("10.0.0.203", 4998))
c:settimeout(5)
local sres, serr = c:send(commandtosend)
local data, rerr = c:receive(5)
c:close()
In my Logic Actions item, I add the following Lua code:
CHANNEL_DOWN()
I save it and run my scene and it doesn’t fire off.
If I take this code and put it in the “test” area of Vera, it works.
What am I doing wrong?
