Hello, im having some problems to setup my camera…
I have :
Mios vera v2 and it says : You are running the latest version: 1.1.1245 .
AVIOSYS IP Video server 9100RK
And a normal hard wired camera.
Everything is running well except the problem that vera doesn’t show the camera image… just says : Trying to get image from camera and shows a red cross.
[quote=“Mitchell, post:4, topic:168868”]But…If my laptop can get the image then vera should to ??[/quote]More than likely, yes. But, the important part with Vera is the URL .jpg part.
Just because that part works in a browser does not mean it’s the same for Vera.
Looks like you may not need the port part for this product. But one thing to check is the camera device in Vera, there are two areas where you can put the IP, under “Settings” and under “Advanced” One area updates the other but I dont recall which one. Check both of the tabs that they are filled in.
