Hi - I’m trying to flash (per instructions) veralite (has blue flashing light issue), however when I set up my static IP on PC and network cable directly to the Veralite I can never manager to PING it?
QUESTION: Could my Veralite unit need replacement? i.e. if I can’t get the network working to be able to perform the flash…
Background:
- Instructions from: http://wiki.micasaverde.com/index.php/Firmware_Flash_VeraLite
- Also got these instructions via support email
Please connect the unit to the laptop using the internet cable, after that you will have to set a static ip for this connection. You will have to add:1st field : 192.168.1.2
2nd field : 255.255.255.0
3rd field : 192.168.1.1Using the terminal you must telnet into the unit and run the next 3 commands but before you do this you must power cycle the unit and when the power lighst starts flashing , you will have to press for one time on the reset button, after you do this the power light should start flashing faster.
