I just got my VeraLite and have it connected to my network, have the controller add to my account, but am hung up after that. The instructions say to log in to co.mios.com. Did that, but the it says to click on myDashboard. I don’t see myDashboard. What am I missing?
You should be able to access your Vera unit from the local ip address. Check your network router to see what ip address was assigned to your Vera unit. Then in the url bar of your web browser, enter the address. You should not have to use cp.mios.com to access your Vera directly. It would also help to know which version of Vera firmware you are running:
Setup → Firmware
- Garrett
