I’ve installed Authomation on my new Xperia Z2 and can’t find the Authomation Widgets. If I use another Launcher the widgets show up, I don’t get it. What am I missing?
Sent from my D6503 using Tapatalk
What you refer to as widgets are actually shortcuts in the app. You’ll have to figure out where these are located in the Xperia’s launcher which I can assume is customized by the manufacturer.
Is there a file for VR I can manually create the shortcut from in a file manager?
