I moved some devices - around changing out on/off switches for dimmers - and want to now swap the device providing the trigger. So instead of light #1 being on, change the trigger to light #2. PLEG GUI allows me to make the change and is all looks correct, but there no save option when I close PLEG device, and when I reopen the device the change is lost. Doing a reload also loses the change. I have tried multiple browsers and a Shift + F5. I can’t find any way to make the change stick.
I would guess that deleting and re-creating the trigger would work, but would complicate the process of moving everything around…
I would guess that deleting and re-creating the trigger would work, but would complicate the process of moving everything around...
Unfortunately you do have to create new Triggers. It is a Vera thing that PLEG inherits. If you delete the Triggers, you will need to refresh the browser page before creating new ones with the same names.
I’ve found that when changing trigger devices, you need to not only select the new device but you also need to re-select the mode:
- Open the triggers in your PLEG
- Click the Edit button for the trigger you want to change
- Select the new device
- Select the new mode (i.e., Device is turned on) - note the Save button is now available
- Click the Accept button
- Close the PLEG and do the Vera-Two Step
I deleted and recreated many a PLEG until I stumbled across this…
(edited to include the Accept button step)
