Is there a way to turn off the creation of automatic devices ?
under devices i can set it to disable but its not saving
Automatic creation: keeps on
Everytime i delete the devices they keep comming back
What version of the plugin are you running?
I assume you are trying to change this in the Managed Devices tab of the RFXtrx device. You may try to go to the Advanced tab of the RFXtrx device and then select Variables. There you should see the AutoCreate variable. Set it to 0 and that should disable it.
[quote=“tinman, post:2, topic:197771”]What version of the plugin are you running?
I assume you are trying to change this in the Managed Devices tab of the RFXtrx device. You may try to go to the Advanced tab of the RFXtrx device and then select Variables. There you should see the AutoCreate variable. Set it to 0 and that should disable it.[/quote]
Thank you for this answer! I had the same problem an was not aware that you could change the variables manualy!
