Can't connect GE 45600 to VeraLite
Hello. I’ve just bought ge 45600 remote, so trying to connect it to my VeraLite. Now i just have two dimmers connected to VeraLite.
In UI5 i go to
Devices-Add devices-Advanced Z-Wave devices-add one
than i go to my VeraLite with my remote, press setup untill two Leds blinks, enter 967 so green led is blinking for a long time.
Than its “Done. Added 0 nodes” on top of UI5, but nothing added.
What is wrong?
If I had to guess, nothing added because you haven’t created any scenes yet that use this remote as the trigger.
It seems that only scene info gets relayed by Vera and associated with buttons on the remote. Some of us have been able to manually associate individual lights once the remote is paired with Vera. However, this hasn’t worked for everyone nor with every 45600. The individual light associations are lost upon updating scene info from Vera and one needs to go back and do it all again. A bit aggravating.
Also, there are problems between this remote and Vera when scenes are assigned to certain buttons. Reviewing the forum posts will bring you up to speed on that problem.
Since you only have a couple of dimmers right now, maybe manual pairing of the 45600 with those devices may be all you need to get you going.
Have you tried excluding the remote first?
