I just installed a Veralite on my FIOS home network. Everything works perfectly when I use a computer on my home network but I can’t seem to access my system from the Internet or a mobile app. I read in one of the forum posts that for UI6, I should use home.getvera.com. When I login from a PC that’s not on my home network I get a message stating “I didn’t detect a unit on your home network” along with basic hookup instructions. Logging into the same sight from a PC on my home network works perfectly. I’m running with firmware version 1.1.641. I’ve attached the Network Trouble shooting log from the UI.
Thanks in advance for helping out a newbie.
=== IP Configuration ===
eth0 Link encap:Ethernet HWaddr 00:0E:8F:6D:59:4B
inet addr:192.168.81.1 Bcast:192.168.81.255 Mask:255.255.255.0
eth0:0 Link encap:Ethernet HWaddr 00:0E:8F:6D:59:4B
inet addr:192.168.1.10 Bcast:192.168.1.255 Mask:255.255.255.0
inet addr:127.0.0.1 Mask:255.0.0.0
External IP: 74.107.100.247
=== Testing Gateway: 192.168.1.1 ===
GATEWAY:OK
=== Testing DnsServer: 192.168.1.1 ===
DNSSERVER1:OK
=== Testing External Servers ===
GOOGLE.COM:OK
STA server: OK
EVT server: OK
TS server tunnel connection: OK
FWD server: OK
FWD server tunnel connection: OK
=== SSH_TUNNELS: ===
Found 1 ssh sessions running
Remote Control Tunnels are running
== DONE ==
