Cannot find plug-in in APPS
Cannot find plug in in the APPS section of UI-5.
Wanting to make sure it works in UI7 before I upgrade…
Can someone point me in the right direction? Haven’t played with VERA much, don’t know Luua code, just want to use the box.
Thanks…
For some reason you can not find plugins you have installed when searching from the UI5 interface. When I search for “Elk Alarm Panel Plugin” I find it just fine since I don’t have it installed.
Maybe you should try here instead → MiOS Apps
