Cannot figure out Fibaro relay settings for Garage door opener
I’m struggling with getting my Fibaro FGS221 2x1.5kW relay switch to operate my Chamberlain GDO. I’ve connected it ok, to each pole on the Chamberlain wired wall switch and I can hear the ‘click’ when the relay clicks on and off but there is no movement of the door. I’m wondering if there are parameters I need to set. Currently I have the relay set up using D_relay.xml and it has the following parameter set…
14 1 byte Dec, set to 0
Are there any other parameters I need to set in order for it to work?
Thanks,
Coj
