I am trying to DL a virtual on/off switch. Every time I try my Vera control panel says Failed to Download All Plugins Will Retry in 10 min.
Is there a LUUP code to create a switch that I could paste into a “new device” to stop having to deal with these download issues?
Not really. You need a set of files for the VirtualSwitch plugin. Are you trying to down load from the Mios App store Here? Can you login under My Account using the username and password you set up for your Vera system (probably the same as for this forum)?
Go to apps.mios.com
Login and select your unit.
Then use the URL below. Which should give you the ability to show files or install. First try install.
http://apps.mios.com/test-plugin.php?id=1408&show=versions
