For some reason I can arm away and arm stay, but when I enter now the code to disarm from the UI7 interface it does not disarm when typing in the code. The app used to work to disarm when entering the code and pressing disarm.
However if I use the IOS app Veramate which supports the same features, it works and disarms with the code normally
No idea, sorry. I’m not on a recent UI7 so I’m not in a position to reproduce the bug. It sounds like a change in the way that a plugin’s static JSON file is processed.
As a workaround, see if you can put the Disarm command into a scene. That more closely resembles what Veramate and other apps do, so it may work where the web UI doesn’t.
