I have tried manually adding some ip cameras, which has created some undefined devices. When i now try to delete them, as they are not working, i get the following error message: command failed: invalid plugin
How can i delete these devices ?
Try using this command in your browser:
http://<Vera_IP>:3480/data_request?id=device&action=delete&device=<device_ID>
Update to reflect your own details…
Many thanks, they are gone !
Thanks! It worked for me too!
Me too. If it is that is easy, shouldn’t the UI be able to do it?
I have added/include a RT CT100 thermostat to a VeraLite. Each time I do two unwanted devices also add to the room. Two do not work but one does.
If I exclude the device all three go away. Next time I include it they come back.
- I can not delete them in their settings box. (click on the wrench on the device)
http://192.168.1.106:3480/data_request?id=device&action=delete&device=5 is not working (I think it does but they just come back).
If I change the name or the room the unwanted device reappear with the default name in the room the working thermostat is in.
WTF?
do a search on this forum, there is a sulution to suppress unwanted devices. cant remember where exactly, but there is a way
The two devices reappearing are children devices of the thermostat and this has been covered a number of times previously in the forum. The way most people seem to have resolve this is be registering a support ticket to have it fixed. An example of a similar thread can be found here. http://forum.micasaverde.com/index.php?topic=14016.0
Yes of course I did do a search and dug up this post.
Brientim - Thanks that’s my problem exactly. I’ll get support involved.
If I can post the solution I will.
micasaverde support fixed it today.
Don’t know what they did.
Did ask if they recommended getting a second CT100, they do.
thanks for the help.
