I have four scenes / Meshbot rules that seem to have gotten corrupted and I cannot edit them and I cannot delete them, which is what I want to do now. I have tried in the Vera mobile app to delete them, in the Ezlogic web GUI and even in the Online API Tool and I cannot get rid of them at all.
Doing a hub.scene.list command in the API Tool I can see they are still in the list of results, this one for example:
However when I try to delete it I get this error: “The scene with this id does not exist”
I will check if something can be done in order to force the removal of those for now while we investigate a little deeper.
I would like to know if perhaps they got corrupted after making some changes or a firmware upgrade or if you can pinpoint what happened prior to them going bad it would be awesome!
Three of them had LUA scripts on their actions. I originally created them in the Vera mobile app when you first released lua scripting on the Ezlo hubs.
Then later they stopped working likely due to changes in the development / architecture etc.
They then got corrupted and I could no longer edit or delete them.
Note for other users Lua scripts are now operational again in Meshbot rules.
And the fourth rule I am having problems with, I’m not sure what happened it was just a regular rule for a lights schedule that is now corrupted.
The names of the problem rules are as follows and they can a be deleted if you can do it.
Globe Lamp Toggle via Lua Code
Globe Lamp On via Lua Code
Globe Lamp Off via Lua Code
Schedule Lounge Lamps ON
If you need access to my Vera user account, just DM me a message.
Got it! that’s good info, at the moment I would need you to enable remote access on that controller and that would be it. (Keep in mind that when you tap the toggle button it will not stay green and visually it will revert back but it will be actually enabled.)
You can either SCP that file into your eZLO and then follow the commented instructions in the file or perhaps just create a file in your eZLO through SSH and then just copy and paste the script.
The only difference is that at the end of the code you were missing an “echo” after I typed it in, it started working, I left the script there if you want to check it out and the scene you were trying to remove is no longer there.
The script I uploaded is ok, perhaps when you copied and pasted it the last reserved word was missing, but I actually downloaded the one uploaded here and it was ok.
If you have more problems with scenes or so let me know.
