I’ve using HomeWave without any issues.
Since I installed RfxCom Usb (alpha 10) to connect to oregon sensors I cannot connect to my Vera from HomeWave (niether LAN nor internet).
Is there any known issue? I’ve done 3 hard reset and is always the same. The same thing happens with SquareConnect.
With the RFXCom plugin installed, can you still connect to Vera via a browser? And while you have the webpage open, does it say “Unit busy” from time to time at the top? If other iPhone apps (SquareConnect) experience the same issue, this would indicate a problem with your Vera or the RFXCom plugin.
I finally managed to solve it. I don’t know if it was related to the usb rfxcom. After lots of hard reset I tried to restore a backup from the first day and then it worked. Now I have rfxcom devices, belkin wemo devices and zwave devices working together and controllable via homewave.
Just a question. What is hard reset doing different than restoring a first day backup?
