Greetings cybermage!
I love the new version of the EVL3 plugin - thank you again for continuing to improve and support this. Yesterday I removed my Vista 15P panel and replaced it with a 20P, with the newest firmware. I completely removed and re-installed the app from the “app store”, and after a bit of a learning curve, I got it working. The only problem I’m having is that it seems the Partition devices in the Vera won’t save the PIN codes permanently, so after a while I can’t arm or disarm either partition. I go into the device properties, enter the PIN, and click the “Store” button - and the value will hold for a while, but I have timed events that run during the day, and these do not fire. When I watch the UI of the Vera, I see this message about not having the PIN code show up in blue at the top. Would you know of something that might be causing this?
I’ll be happy to provide any debugging logs or info that you need - just tell me what to do! ![]()
Thanks so much!
