Sorry. It took a while before my post went live and I since fixed the issue.
As my Vera was brand new it obviously shipped with instructions on upgrading to UI6 Firmware 1.6.641. Which as far as I’m aware is still in Beta stage. Thus the whole interface seemed very very clunky.
Problem was that the old mios login (MiOS) is not compatible with UI6. My understanding is that there will be a new login etc for UI6.
I have now downgraded to UI5 Firmware 1.5.xxx and all is well in the world. The interface is smooth and how I expected and I was able to add my Vera immediately via the original login method. All is working fine now.
I am having the same problem i think, but i may have overdone it.
On the “getvera.com” I have set up a username “jimoverstreet” with my email address and a “new password format” (including a special character) when first set my veralite up, and can use the new ui6 dashboard as well as the “advanced”
then when trying to figure out how to remotely access, i set up a “cp.mios.com” account with the same “jimoverstreet” username and email address, but different “old password format” (no special character).
i get the same reaction above on the mios.com system. do i need to delete the “mios.com” account or how do i do that. how do i register on the new iu6 so that i can use remotely with iPhone or whatever?
cp.mios.com is for UI5 only. If you are on UI5 1.5.622 on your vera you use this service. If you are on UI6 1.6.641 you will need to use getvera.com. They will not work interchangeably.
I have the same problem. The dashboard says No devices have been added to this account. Then after clicking on Assign device and the following it is written Unit added to account, but the dashboard exactly says the same like before. What am I doing wrong?
Hello kaihawaii,
We looked into your issue. You bought your unit from ebay but it seems this unit was from a lot with a different destination and had different settings. We have updated the servers to accept your unit and you will be able to add it now to your account.
If you have any more issues leave a message on the forum or contact support.
Vlad
[quote=“kaihawaii, post:10, topic:179629”]I have the same problem. The dashboard says No devices have been added to this account. Then after clicking on Assign device and the following it is written Unit added to account, but the dashboard exactly says the same like before. What am I doing wrong?
I go back to myMiOS and hit the same point as step 3!!!
What on earth am I doing wrong? It seems so very simple yet it just won’t add!
I’ve tried doing it on my phone, in Firefox and in IE.
I see the issue was resolved by Vlad who I’m hoping can also assist- I want to be able to access vera remotely but at this point i can only do it from within the house.
New guy here. Bought my unit from tiger direct and it came pre-loaded with You are running the latest version: 1.6.641 and I MiOs won’t allow me to add my unit. It “sees” it and brings up the unit number, but when I click to add the unit it just goes into some sort of infinite loop. Big reason I bought the unit is being able to check in on my home when I’m away.
Can’t add unit to MiOs → no app on smart phone → unit goes back and I take my business to another company.
Anyone able to successfully get a 1.6.641 unit to work with MiOs and the apps.
Also the new interface won’t let me add another user…always fails to add user.
Trying to add Vera Lite v1.5.286 to my existing MIOS account with VERA 3 v 1.5.622
under ACCOUNT/VERAS/“Unassigned units in the same network”
i can see the ID number of the new (Vera Lite ) unit with button “Add unit”
pushing the button just get :“Connecting to unit, please wait” without any further results.
