On the HSM100 there is a place in settings to set motion sensitivity as an option. I figure there may be a way to do it on the Aeon 4in1 however if so, its not straightforward. If doable, that would range of numbers be and what would be variable and data size?
(I searched and found options for wakeup, pir enable, motion timeout… etc… no motion sensitivity).
Thanks!
Les
