Hello,
I have this setup:
[ul][li]Fibaro Z-wave RGB controller attached to LED Light Strip[/li]
[li]Zipato RGBW Zwave Lightbulb[/li][/ul]
In Vera, I can control the color for the Fibaro through a plugin called RGBW. I can select my color on the Vera web access through that plugin. With the Zipato, I can control it directly through the Vera app. I noticed that I can’t set the color for either of these devices. I can turn them on and set the brightness. But that’s it. Does Veramate have a setting for RGBW somewhere?
