Can´t connect to my Vera after Update to UI4
My Vera worked fine with UI13 until today.
Then I tried to update to UI4 like described in this post:
http://forum.micasaverde.com/index.php?topic=4141.0
I waited about 20 minutes, but I didtn got a message that it is done. So I pluged off/in the power like it says there.
When I then followed the link http://cp.mios.com/
I got this message:
[i]
New MiOS systems on your home network
I found 1 new MiOS systems which have not yet been assigned to a myMiOS account. Click “Add to myMiOS account” if you want to setup or use these systems.
Unit_xxxxx
Serial #xxxxx // IP: 192.168.0.22[/i]
But when I click on “Add to myMiOS account” I stuck at:
I am trying to connect to your unit using local network connection.
One moment while I try contact it on your local home network.
If you still see this message after 15 seconds, please reset your unit, wait one minute then click here
I tried to plugin out/in the power of my Vera and router, without success.
If I try to reconfigure it at http://micasaverde.com/vera2
I got this:
I found more than 1 Vera on your network. Which one do you want to setup?
#xxxxx 192.168.0.22
When I click setup →
ERROR
Cannot communicate with your Vera.
I don´t know what to do… need help to get my Vera back to work :frowning:
I tried to upgrade from UI2 to UI4 on a Vera 1 and experienced the exact same issue you are having just a few days ago. I could not get Mios to register the unit. I finally gave up after a few days since I needed to get Vera back online. I re-flashed my unit to UI3 which worked.
Same problem here after upgrading from UI2 to UI4.
I aslo can upgrade from 1.1.992 tp 1047 it just hangs and I have to do a factory reset.
Anyone have any ideas?
I just jumped in and have the exact issue described by Loide above…did anyone ever respond to this?
