I am replacing my old Vera 2 with a couple of Vera lite’s and and can’t seem to get the first vera to connect. I’m using my usual log in but have disconnected my Vera 2. I do not want to use my old settings or a back up because it was such an unholy mess that it would just be much faster to remove and re-add all my devices. Do I need to create a new account?
EDIT
As an added bonus, I can not submit a ticket because the “Submit” button isn’t an actual link on tech support. REALLY going to depend on the forum for this one so if anyone can help I would appreciate it.
There should is no need to create an new account unless they are UI6 or the firmware is auto upgrading to UI6.
As this is the initial setup try using:
http://cp.mios.com/setup
Otherwise, this may assist:
http://forum.micasaverde.com/index.php/topic,22736.msg153190.html#msg153190
Using UI5, I ended up making a new account and it fine for the first “main” vera but now I can not get that Vera (we’ll call in “main”) to see the second vera to bridge them. When I go to the MiOS, I can see it and made sure they had the same UI versions installed. When I go to add UPnP, it does not show up.
Don’t sweat it too much. I have multiple veralites and had to have Micasaverde bridge all of them. Open up a ticket and they will usually respond within one day.
they connected, bridged them and sent me an email when they were done.
[quote=“Bulldoglowell, post:4, topic:179207”]Don’t sweat it too much. I have multiple veralites and had to have Micasaverde bridge all of them. Open up a ticket and they will usually respond within one day.
they connected, bridged them and sent me an email when they were done.[/quote]
Excellent…thanks. Would be nice to understand what’s going on under the hood for when this inevitably breaks though.
