I would like to use device group associations to turn lights on with motion detectors for near instantaneous response for walking into a room. However, I would like some enhanced Vera logic for turning lights off.
Currently, there is a 1-2 second lag when using Vera routing that I would like to avoid. When setup for direct association, it will shutoff the light after the no-motion timer elapses (10 minutes in my config), however, there may be other logic needed to turn off a light (and a delay of a few seconds won’t be as obvious).
My specific hardware scenario is using EZMotion+ 3-in-1 Sensor to turn on a Leviton dimmer light switch.
PS - I wasn’t sure to put this in Lighting, Motion, or general…but since it is cross function and Z-wave specific, guessed on General forum board. Sorry if it is in the wrong place.
