Can I use multiple ZWave frequencies (USB Zwave?)
I’m trying to find out whether I can run a single Vera with both the internal zwave controller and an external USB controller.
I currently have some US freq Zwave automation stuff, but they are now releasing the AU frequency zwave stuff and it would be nice to switch over.
I believe i could run two Vera’s one on each frequency and then network them together, but was hoping it would be possible to do the same with a single Vera
Can anyone tell me whether this is possible?
Thanks in advance
I don’t think its possible as it seems there is only one place in the settings to enter a “single” Zwave dongle port and this has to be either an internal OR an external one. I would either go the dual Vera route (the latest builds are supposed to support this) or try to sell your 900 MHz stuff to someone in the US and go legal :slight_smile:
I can confirm. You can only setup one Z-Wave port on the Z-Wave Device > Options tab.
