[quote=“Z-Waver, post:2, topic:191028”]A heal will run automatically overnight.
By now, your devices should be working.[/quote]
Yes they seem to work now. For the future is there any way to trigger this so you don’t have to wait overnight?
-- Initiate Z-Wave network heal.
-- Intended for starting heal after adding new devices.
-- Depending on the size of your network, a heal can take a very long time.
local URN = "urn:micasaverde-com:serviceId:ZWaveNetwork1"
local ACT = "HealNetwork"
local BATT = {BatteryMinutes=30} -- Default 30. Nightly 60.
local ITR = {StressCycles=2} -- Default probably ample.
local START= {StartStage=1}
local STOP = {StopStage=3} -- Default 7. UI7.10 or greater probably needs to go no further than 3.
luup.call_action(URN, ACT, BATT, ITR, START, STOP)
Using the above request or luup code will mess up the mesh network and nodes will stop working correctly. This method is in contradiction to our currently implemented Z-Wave healing process that updates the route and lets the chip itself manage the routing table as opposed to the previous method where the gateway kept the routing table.
