Using latest firmware.
I set the camera position, and the next day the camera is reset to pointing at the ceiling. I reset it and the next day or so it is back at the position of initialization.
Can’t seem to lock it in place.
I never had this issue with the legacy server, only after upgrading to the new vera.
Thanks in advance.
[quote=“heynowjerry, post:1, topic:191926”]Using latest firmware.
Thanks in advance.[/quote]
Any ideas? Camera keeps resetting to initial position, pointing up in the air centered.
You need to go to the web address of your camera in a browser tab.
http://ipofcamera:port/main.htm
Go to “system” > PT Settings > After the call to start the preset position. Change this to the preset position you want it to be at.
