Camera IP Issue -Latest UI7 Release
Just load the newest ui release on Sunday. There was some issues with the cam prior to upgrading, but now the IP I put in does not hold. Vera switches it back to another IP in less than 1/2 day. Reset it, and after a while it goes back again. Anyone have an idea why this happens.
If you have the Mac address field populated with a value in the camera settings, remove the value and save. This should solve your problem.
  • Garrett
Thanks. Also noticed that Vera must of done a quick fix as the version appears to have changed and was able to upgrade again. Must of been a few issues.
