I have some webcams I can access by an address like http://…/image.jpg
How can I add this image to Vera?
If I just paste this and use other IP camera it doesn’t work.
In the URL field you should only put the part of the URL that comes after the host (in your case, /image.jpg).
Perhaps a screen capture of the Settings tab would help. (Edit: here’s one of mine)
The webcam is not locally.
However it works now. I just added the web address without http://.
Can I adjust how often this image is refreshed (polling)? I assume it only refreshes when I’m viewing it unless I enable archiving.
