The name and device type both end up being “undefined”. It wouldn’t let me delete them, it came back with some invalid plugin error, but I figured out how to delete them through port 3480.
I’m using the Manually Add link when adding a camera. I have a mixture of cameras, but I’m testing with the Sharx ones now (same thing as Y-cam). Other people seem to have it working by using /snapshot.jpg, but for some reason it’s creating the device wrong for me. Thoughts?
I have 4 Foscam Fi8910W with MCVFlorin’s plugin. Ever since I added the last 2, Vera randomly creates zWinTop camera devices with the same IP’s as the Foscams. I’m unsure what plug-in they are using but when I delete teh zwintop and it’s plugin it doesn’t affect the Foscam plugin and the 4 FI8910W cams hooked into that.
I notice when Vera does that as the zWinTop ones will show up on the camera list when I run Vera Remote.
All 4 cams are hooked into Vera’s WiFi. It’s not debilitating but it is kinda irritating. Any suggestions or ideas what may be causing this? It seems to happen after a power failure (being in Tampa Bay, brown-outs are a fact of life thanks to Tampa Sometimes Electric) Unfortunately I have no way of hooking them up to a UPS.
The auto-detection mechanism in Vera will incorrectly detect a Foscam as a zWinTop camera if the Foscam is password protected (with your own username / password). (Prior topic.)
@OTI@: Thank you. I had searched but must have missed that one. The weird thing is that the zwintop dupes only happen for the last 2 added Foscams. The first duo has no problems. All are FI8910W’s. The only difference is that 1 and 2 are white and 3 and 4 are black. I’m sure I set them all up identical, but I’ll go over the settings again with a fine toothcomb.
@ufd108
The 2 that don’t cause zWintop dupes are both
Device Firmware Version 11.37.2.46
Device Embeded Web UI Version 2.4.10.2
Of the 2 that cause the zWintop dupes one is the same as above, the other is
Device Firmware Version 11.37.2.44
Device Embeded Web UI Version 2.4.10.1
I did notice something scouring over the settings. The first 2 had a MAC address that did not tally with the Device ID. I remember hooking them up to Vera wired first to config the wireless. So the MAC that’s in there is the one for the wired jack most likely. The last 2, I hooked wired to my normal LAN. Those do have the correct MAC address listed. I corrected the MAC address on the first 2 to match the Device ID on the camera status page. Lets see if now I get 4 zWinTop dupes instead of 2.
