Call for testers of new UI for Squeezeboxes
Use an IR remote and a Squeezebox/Squeezebox Server to control Vera:
Run Vera’s scenes and control Vera’s devices.
System setup
IR remote → Squeezebox <-> SBS <-> Vera with UI for Squeezebox <-> Vera’s Scenes/Devices
Menu layout for Squeezebox
[tt]
Room 1 → Scenes → Scene 1 → Run Scene
Room 2 → Scene 2
Room 1 → Devices → Device 1 [status information] → Action 1 → Execute Action 1
Room 2 → Device 2 [status information] Action 2
[/tt]
Preliminary installation instructions
[tt]
– INSTALLATION
– 1. [@SBS] Backup ???.ir to ???.ir_original
– 2. [@SBS] Replace the contents of ???.ir with:
– =============== snip =================
– 3. [@SBS] Add the following lines to Default.map, just below ???:
– 4. [@SBS] Stop and restart your SBS
– 5. [@IR remote <> original Squeezebox remote] Configure your IR remote to send JVC DVD/VCR IR codes.
– [@SBS] For advanced SBS users:
– Any IR remote which can be ‘read’ by the Squeezebox and whose IR codes
– are different from the IR codes of the original Squeezebox remote can be used:
– Set the logging category ‘player.ir’ to debug, press the buttons on your remote,
– and inspect the log file in order to get the corresponding IR codes which can be
– used in step 2 above instead of the JVC DVD/VCR IR codes.
– Do not forget to lower the logging level for ‘player.ir’.
– 6. [@Vera] Adjust SBS_IP_address and playerid (see sticker on bottom of your Squeezebox)
– accordingly, then copy this script into the ??? window and press the ‘Go’ button.
– The script will exit after about 60 ??? seconds.
– 7. [@IR remote <> original Squeezebox remote] In the meantime, enjoy your new UI:
– Use the buttons 2 (up), 4 (left), 6 (right), 8 (down) on your IR remote to navigate through
– the menu.
[/tt]
I am looking for pre-beta testers for this new UI. If you are interested and if you have the
necessary equipment
[ul][li]Vera[/li]
[li]Squeezebox Server[/li]
[li]Squeezebox with display and built-in IR receiver (but not Squeezebox Radio, see Slimdevices bug #15749)[/li]
[li][universal] IR remote which can send IR codes for JVC DVD/VCR
(or the skill to get the IR codes for your remote from the SBS log file)[/li][/ul]
please PM me.
I am especially interested in testers who are using Z-Wave HVACs, PTZ cameras, and Z-Wave door locks.
Pre-beta code will be available in about two weeks.
Pre-beta code is available right now.
