Hello,
I’m trying to configure this plugin with this type of connection:
Caddx nx584<–>serial to usb<–>Raspberry ser2net<–>Vera
I test the connectionn with dl900 software “Caddx nx584<–>serial to usb<–>pc running dl900” and this works OK
I telnet the ser2net ip/port from this pc (putty) and telnet connection from shh vera returns:
On ser2net I add this line:
1234:raw:0:/dev/ttyUSB0:9600 1STOPBIT 8DATABITS NONE
I setup nx584 with binary and 9600 baud
I put the ip:port on advanced tab of plugin but Vera returns: Caddx NX584 Security[91] : Failed to set up interface
This is the log:
50 01/18/17 11:51:39.146 luup_log:91: Initializing Caddx NX-584 <0x77516520> 50 01/18/17 11:51:39.146 luup_log:91: Opening socket to 192.168.0.209 port 1234 <0x77516520> 50 01/18/17 11:51:39.249 luup_log:91: Sending message and waiting for response: 0x21 Interface Configuration Request <0x77516520> 50 01/18/17 11:51:39.250 luup_log:91: Message: Outgoing: 0x7e 0x01 0x21 0x22 0x23 <0x77516520> 02 01/18/17 11:51:39.263 IOPort::Run RecvFailed 0 close 14 <0x74f16520> 02 01/18/17 11:51:43.100 ZWaveJobHandler::AlarmCallback skipping check because of jobs <0x77716520> 02 01/18/17 11:51:44.283 IOPort::Run RecvFailed 0 close 14 <0x74f16520> 02 01/18/17 11:51:48.344 ZWaveSerial::GetFrame 0x76f15bd8 timed out now 0 m_listGetFramePending 0 <0x76f16520> 02 01/18/17 11:51:48.344 ZWaveJobHandler::SendDataAbort got m_iFrameID 0 <0x76f16520> 02 01/18/17 11:51:48.345 ZWJob_SendData::ReturnMessageNotReceived job job#6 :setpoint support node 2 dev:49 (0x8ab9d0) N:2 P:38 S:5 to node 2 command 0x43/0x4 retries 0 of 2 quit 0 returned m_iFrameID 0 <0x76f16520> 02 01/18/17 11:51:48.433 ZWJob_SendData::ReceivedFrame ok job job#6 :setpoint support node 2 dev:49 (0x8ab9d0) N:2 P:38 S:5 to node 2 command 67/4 took 1 retries resend: 0 waiting 67/5 got 0 <0x77716520> 50 01/18/17 11:51:51.844 luup_log:91: Received inconvenient message 0x04 <0x77516520> 50 01/18/17 11:51:51.844 luup_log:91: Message: Unsolicited message body: 0x05 0x01 0x58 0x13 0xf0 0x09 0x02 <0x77516520> 50 01/18/17 11:51:51.845 luup_log:91: Sending message: 0x1D Positive Acknowledge <0x77516520> 50 01/18/17 11:51:51.845 luup_log:91: Message: Outgoing: 0x7e 0x01 0x1d 0x1e 0x1f <0x77516520> 50 01/18/17 11:51:51.846 luup_log:91: Message: Outgoing: 0x7e 0x01 0x21 0x22 0x23 <0x77516520> 02 01/18/17 11:51:51.854 IOPort::Run RecvFailed 0 close 13 <0x74f16520> 50 01/18/17 11:51:56.877 luup_log:91: Ignoring byte 83 <0x77516520> 50 01/18/17 11:51:56.887 luup_log:91: Ignoring byte 45 <0x77516520> 50 01/18/17 11:51:56.898 luup_log:91: Ignoring byte fe <0x77516520> 02 01/18/17 11:51:56.908 IOPort::Run RecvFailed 0 close 13 <0x74f16520> 02 01/18/17 11:52:01.474 ZWaveSerial::GetFrame 0x76f15bd8 timed out now 0 m_listGetFramePending 0 <0x76f16520> 02 01/18/17 11:52:01.475 ZWaveJobHandler::SendDataAbort got m_iFrameID 0 <0x76f16520> 02 01/18/17 11:52:01.475 ZWJob_SendData::ReturnMessageNotReceived job job#6 :setpoint support node 2 dev:49 (0x8ab9d0) N:2 P:38 S:5 to node 2 command 0x43/0x4 retries 1 of 2 quit 0 returned m_iFrameID 0 <0x76f16520> 02 01/18/17 11:52:01.563 ZWJob_SendData::ReceivedFrame ok job job#6 :setpoint support node 2 dev:49 (0x8ab9d0) N:2 P:38 S:5 to node 2 command 67/4 took 2 retries resend: 0 waiting 67/5 got 0 <0x77716520> 50 01/18/17 11:52:04.472 luup_log:91: Received inconvenient message 0x06 <0x77516520> 50 01/18/17 11:52:04.472 luup_log:91: Message: Unsolicited message body: 0x00 0x00 0x00 0x00 0x00 0x02 0x00 0x83 <0x77516520> 50 01/18/17 11:52:04.473 luup_log:91: Sending message: 0x1D Positive Acknowledge <0x77516520> 50 01/18/17 11:52:04.474 luup_log:91: Message: Outgoing: 0x7e 0x01 0x1d 0x1e 0x1f <0x77516520> 50 01/18/17 11:52:04.474 luup_log:91: Message: Outgoing: 0x7e 0x01 0x21 0x22 0x23 <0x77516520> 02 01/18/17 11:52:04.483 IOPort::Run RecvFailed 0 close 13 <0x74f16520> 02 01/18/17 11:52:09.518 IOPort::Run RecvFailed 0 close 14 <0x74f16520> 02 01/18/17 11:52:14.594 ZWaveSerial::GetFrame 0x76f15bd8 timed out now 0 m_listGetFramePending 0 <0x76f16520> 02 01/18/17 11:52:14.595 ZWaveJobHandler::SendDataAbort got m_iFrameID 0 <0x76f16520> 02 01/18/17 11:52:14.595 ZWJob_SendData::ReturnMessageNotReceived job job#6 :setpoint support node 2 dev:49 (0x8ab9d0) N:2 P:38 S:5 to node 2 command 0x43/0x4 retries 2 of 2 quit 0 returned m_iFrameID 0 <0x76f16520> 02 01/18/17 11:52:14.596 ZWJob_ConfigureNode::ChildChanged aborting job#2 :conf_jh#2 dev:49 (0xb106d0) P:39 S:5 for job#6 :setpoint support node 2 dev:49 (0x8ab9d0) N:2 P:38 S:5 <0x76f16520> 02 01/18/17 11:52:14.596 Device_Basic::m_eConfigured_set device 49 was -2 now 0 zw aborting <0x76f16520> 01 01/18/17 11:52:14.599 ZWJob_SendData::JobFailed job#6 :setpoint support node 2 dev:49 (0x8ab9d0) N:2 P:38 S:3 Priority 38 <0x76f16520> 02 01/18/17 11:52:14.602 JobHandler::Run job#3 :conf_jh#3 dev:53 (0xb109b0) P:40 S:0 is 39.729855000 seconds old <0x76f16520> 02 01/18/17 11:52:14.628 Device_Basic::m_eConfigured_set device 53 was -2 now 1 zw configured <0x76f16520> 02 01/18/17 11:52:14.634 JobHandler::Run job#4 :conf_jh#4 dev:57 (0xa18cd0) P:40 S:0 is 39.739642000 seconds old <0x76f16520> 02 01/18/17 11:52:14.650 Device_Basic::m_eConfigured_set device 57 was -2 now 1 zw configured <0x76f16520> 50 01/18/17 11:52:17.114 luup_log:91: Received inconvenient message 0x06 <0x77516520> 50 01/18/17 11:52:17.114 luup_log:91: Message: Unsolicited message body: 0x00 0x00 0x00 0x00 0x00 0x02 0x00 0x83 <0x77516520> 50 01/18/17 11:52:17.115 luup_log:91: Sending message: 0x1D Positive Acknowledge <0x77516520> 50 01/18/17 11:52:17.115 luup_log:91: Message: Outgoing: 0x7e 0x01 0x1d 0x1e 0x1f <0x77516520> 50 01/18/17 11:52:17.116 luup_log:91: Message: Outgoing: 0x7e 0x01 0x21 0x22 0x23 <0x77516520> 02 01/18/17 11:52:17.125 IOPort::Run RecvFailed 0 close 14 <0x74f16520> 02 01/18/17 11:52:21.676 Device_Basic::AddPoll 53 poll list full, deleting old one <0x77716520> 02 01/18/17 11:52:21.679 JobHandler::Run job#8 :pollnode_conf #4 dev:57 (0xb8f448) N:4 P:40 S:0 is 7.26852000 seconds old <0x76f16520> 02 01/18/17 11:52:22.147 IOPort::Run RecvFailed 0 close 13 <0x74f16520>
Can you help me succeed with the connection?
Thanks a lot
