Just installed the AD2USB, all of my Ademco Vista 20P zones show up , and for the most part everything works fine… However - the bypass button in the zones created by the plugin don’t seem to do anything. I assumed that they would bypass a faulted zone and allow you to arm the system… So… I am wondering if I have a basic misunderstanding of how this is supposed to work - or if my implementation is not working correctly. I would appreciate any thoughts on this. Thanks!!!
The bypass / arm buttons on the zones created in vera are only for use in scene control. Say have a light turn on when zone is armed but not when in bypass.
Hope that helps.
Thank you Steve! That makes perfect sense! ![]()
