I want to do an initial Zwave setup based on conversations with friends. I plan on purchasing a veralite to base my setup around, but had a question:
Has anyone solved the issues of the low loads posed by dimmers and LED lighting? I am trying to go green with the lighting as much as a I can. I plan on using a bank of 4 LED Can (Par-type) in the kitchen and 6 in the living room.
When I last checked this was a major issue with LED.
I appreciate the assistance as I am trying to get the WAF for this.
Use the correct dimmer, with neutral. Use a dimmable LED bulb.
I have Evolve LRM-AS dimmers with loads as low as 6 watts and zero issues. No, dummy loads or other workarounds, no humming or buzzing or flickering or heat when off.
Leviton dimmers work too and there may be others.
Dimmers without neutral wires are not appropriate for LED applications. LED bulbs that are not specifically dimmable are not appropriate for dimming applications.
If you want to go green, putting in resistive dummy loads seems a bit counterproductive but certainly better than say using halogen lighting. The metal cased resistors they are using may not be suitable for higher line Voltages, such as 240V. So that needs to be considered/checked. The Fibaro Bypasses may work for you. It looks like the Fibaro Bypasses is an avenue that has not been fully investigated by forum members. Probably because of their cost. I would suggest (but don’t know for certain) that they are just a capacitor and resistor in series - typically used to snub out arcing across relay contacts. The bypass would allow a small amount of AC current to leak through to the dimmer at all times, allowing it to always function when the dimmer load is not high when the dimmer is at “full dim”. The Fibaro Bypass may just be one of these:
Regardless the purely resistive dummy loads are a very workable option.
