People were reporting sometimes they were getting the following error when starting grasshopper.
The text associated with this error code could not be found
I finally have been able to reproduce the issue. It has to do with the code that updates the phrase lists for the voice commands. I thought this was going to be a quick fix but it seems i might have hit a bug in the microsoft api. Other than being annoying it should cause no issues. I’ll push out an update a soon as i get a handle on what is causing it. Thanks.
