Before I give up on using my relay buttons as scene triggers…Has anyone successfully accomplished triggering a scene based upon a button push from the Wink Relay? I’m running into an issue where no matter which relay is used, it will only trigger the scene created for the relay in my son’s bedroom.
Looking at the log it is clear that I’m pushing the button on the relay in my master bedroom and yet it triggers the wrong scene… Based upon what I can see in the log it appears to have something to do with the processDeviceState function.
I’ve attached a small portion of my log showing clearly that two different buttons are pressed on different relay devices and yet in each case processDeviceState returns 397 for the vera id (which is my sons relay).
Anyhow… any one else played with this at all yet?
