I am using Panasonic BC-C1A IP camera. I am unable to change the default password. That it IMHO a security issue, as all vera users will be forced to use the same password for their
IP webcam
IP webcam
The password from the Panasonic IP camera ( that you set it in the own configuration page of the camera ) or the one that you set in Vera to access the camera, you can’t change it?
I think that after you read this wiki page: [url=http://wiki.micasaverde.com/index.php/Panasonic_IP_Cameras]http://wiki.micasaverde.com/index.php/Panasonic_IP_Cameras[/url] you’ll find out how to change it.
If still not I’ll try to post here a step-by-step guide.
More wiki pages about IP Cameras:
http://wiki.micasaverde.com/index.php/IP_Cameras_Options
My bad - I could not get it working the first time, but the second time it worked just fine. Thanks for the help!!
By the way, I would suggest that you change the HTML code doe for the password field in vera for IP cameras to show the text entered as “****” in stead of clear text. I am often demonstrating the system to others, and do not like revealing my password for the webcam.
You can change the password input field for your Vera unit to show it in ****. It has ben already discussed why we keep it that way.
Login to your vera (using telnet or ssh) and execute this commands
grep -n “camera_password_” /www/cmh/js/scripts.js; echo -e “\n\n”
sed -ir ‘/id="camera_password_/s/password <input type="text"/password <input type="password"/g’ /www/cmh/js/scripts.js
echo -e “\n\n”; grep -n “camera_password_” /www/cmh/js/scripts.js
*Only the sed command will do the changes, grep will show you how it looked before and after the scripts.js file, so you could do other changes by yourself also.
Can I recommend a wiki page devoted to SSH’ing into Vera (and copying files)? There are bits and pieces of it at various places, but not a nice, clean, devoted page. I would make sure it includes the following:
I could do this, but I feel like I am just relearning the *nix world again after being gone for a long while.
D.
We’re not encouraging newbie people to mess around Vera’s files and then came to us that Vera doesn’t work any more. You do this on your own, and you do it only if you’re knowing how to do it.
Else send us a message to support and we’ll help you.
Since there are mentions of using SSH and SCP by Micasaverde staff, I thought having clear instructions would decrease support rather than increase it. However I can see that if someone does not know how to do it, they may not try, and that would weed out some of the folks you hope don’t try.
I’d still lean towards documenting it though, as from a customer standpoint, having support people mention something with no instructions available is frustrating. In case you think I may not understand your perspective - I do. I have almost 20 years IT experience, including managing embedded software and help desks.
D.
Hey CJ. Thanks for the pointer concerning the password. It worked perfectly, and now I have a normal HTML password field with “***” - super!!
