I’m currently traveling internationally (from the US) and the last time my iPhone Locator instance correctly updated was while I was in the US (at the airport).
I’m also seeing the MsgText being all messed up.
With DEBUG enabled, it’s clear that the device (iPhone) is returning location data, so I suspect the plugin is having problems calculating the distance (which is now several thousand miles).
50 03/10/15 4:03:36.852 luup_log:235: IPhoneLocator: loop: an error occurred during execution of forceRefresh():[string "local mime = require('mime')..."]:541: attempt to index field 'distance' (a nil value) <0x2d359680>
50 03/10/15 4:03:36.853 luup_log:235: IPhoneLocator: getPeriodForDevice(235) - Distance:263.119 Auto:1 Base:60==>3600 <0x2d359680>
50 03/10/15 4:03:36.864 luup_log:235: IPhoneLocator: Period chosen for device:235 = 3600 <0x2d359680>
06 03/10/15 4:03:36.865 Device_Variable::m_szValue_set device: 235 service: urn:upnp-org:serviceId:IPhoneLocator1 variable: MsgText was: Poll: 2015-03-09 03:31 / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s now: Poll: 2015-03-09 03:31 / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s / 3600 s #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2d359680>
