See attached Status HTM file.
I cannot name a Conditon “MorningON” or “MorningOFF” - PLEG renames them to add a numeric 1/2/etc at the end.
I’m not sure why this occurs. It does not do it with EveningON or EveningOFF
I initially created this PLEG and a bunch of inputs/conditions/actions… most with the same names. BUT after doing a SAVE, it did not save and all my Conditions & Actions were gone - thus, I redid it in the same PLEG. But again, these were the same text names and only the MorningON/OFF have a problem.
While this is not a huge issue and I can leave it as-is… there must be some bug causing this I thought you should be aware of.
