Hey Guys - pretty new to Vera/Mios in general (this is my first real device - which I already had - waiting for others to arrive). I figured I’d get power data flowing into Vera…wow what a challenge (or perhaps that’s just being new to Vera).
I followed through the brultech thread about getting it setup and running and I must be doing something incorrect… would someone who has this running point me in the right direction? I’ve included what I have today (screenshots included).
Brultech ECM-1240. I’m connected to it via the serial to Ethernet adapter. The Brultech Ethernet module has a static IP of 192.168.1.30 /24.
I have a Vera Lite (IP 192.168.1.2 /24) running 1.5.622. I have installed the Brultech App from the store - it created 7 monitor devices for the CT’s.
Following the Brultech guide (http://forum.micasaverde.com/index.php/topic,5518.0.html).
As instructed in the guide I used the Brultech Interface Assistant to set the Packet Format to HTTP (see ECM-1240 Settings Attachment).
The Serial Ethernet component is configured as explained in the guide - (set to Server). Server IP is the Vera and I see the following line in the Vera Lua log
" 04/14/13 18:55:10.136 luup_log:4: Brultech PowerMeter: Running Network Attached I_BrultechPowerMeter.xml on 192.168.1.30:5000 Device# 4, id LEAK this:65536 start:65536 to 0xf6e000 <0x2bf65680>"
However I’m not seeing any data in the Device (within Vera). Can anyone point me in the right direction?
I see a lot of posting about how to grab URL data or to set the post URL etc but I never saw anything like that - perhaps that’s what I’m missing. Any advice would be great ly appreciated.
Thank you all in advanced ![]()
Andrew
