I have a new Vera3 with a small set of devices and setup has been fine; however, in the cmh_ui6 UI, all of the help links are broken.
Clicking, for example, on this link: “New user? Read Getting Started guide,” I get the following URL:
http://www.doc_server.com/doc.php?language=1&page=getting_started&version=1&skin=mios&firmware=1.6.641&platform=3Pro&manual=1
The same is true even for the ? links in the device settings.
It seems as though “doc_server” were the name of a variable that has not been given the correct value.
Experiment has shown me that the following values do not work:
support.getvera
wiki.micasaverde
For UI5, would the value of “doc_server” would seem to be “docs5.mios.”
Could someone please tell me what the correct value is, and, even better, where to set it in my Vera3 so that the help links work?
Vera support replied:
MAR 06, 2014 | 04:46AM PST
Hi Tom,
Since the UI6 is a new release we are still working on the documentation. Sorry for the inconvenience.
Clicking on the “Advanced settings” brings you to the oldest UI5 interface. So all the existing documentation for UI5 should help you.
You can check the following links:
http://support.getvera.com/
http://docs5.mios.com/doc.php
If you have any other questions please let me know.
Thank you for your understanding.
Regards,
Dennis Nastasa
Vera Smarter Home Control
Technical Support Team
