Hi
plugin broadlink concierge. It’s not clear how to use the application, give me instructions on setting up and using the application. my mail is
dim*
admin edit: private data. (use PM)
Hi
dim*
[quote=“dima-357, post:21, topic:197633”]Hi
dim*
admin edit: private data. (use PM)[/quote]
First you need to get concierge working, and setup broadlink ie
The vera plugin enables you to control broadlink devices from Vera. If you want to do that, then:
Personally I use the virtual switch plugin to create a switch that fires off the scenes I want - eg I have one scene called ‘fireplace go’ that turns on the fireplace, and one called ‘fireplace nogo’ that turns it off. I then use the virtual switch so that when it is turned on, it runs the scene ‘fireplace go’ and when it is turned off it runs the scene ‘fireplace nogo’. That way I can say ‘OK Google. turn fireplace on’ and concierge turns the virtual switch on that in turn activates the ‘fireplace go’ scene so the fireplace turns on… I can also use that virtual switch in, say, Imperihome
So, I’ve been trying to use the concierge with a Broadlink RM4 Pro Wifi… I’ve got Concierge setup and working fine (running on a Synology NAS I have), but when I navigate to the broadlink setup, Concierge cannot find my device. Has anyone tested it with RM4? Any ideais?
Thank you!
