After using IH along side AHD for a few weeks now I have updated my review.
I’ve been using Authomation HD (AHD) since early days and only recently tried IH.
This is a critique from a new user of IH and a user of many automation GUIs over the last 20 (yes 20) years, not meant to just be complaining.
What I like:
- NFC; I like that it exists but too limited currently, needs more features, see “Could use improvement” section below
- multiple system support
- Favorites
- Custom Dashboards, nice but has gaps and usage issues (see below)
- Multiswitches are separated into separate items on the IH screen … very useful!
- Integration with a Vera plugin that can do cool things like bring up a camera feed (even though this is VERY limited and doesn’t support my Samsung SmartCams)
Features needed that do not exist or Need improvement:
- Android Device Shortcuts for quick access to a single device. Great for replacing your garage door opener, quick access to lights, etc.
- Android Widgets … for showing status of devices. Great for monitoring security
- NFC is too limited currently… needs: trigger/set any device in Vera (switches, multiswitches, etc); open to a Dashboard … useful moving from room-to-room to have a dashboard for each room, or even your car
- Lack of quick access Group (room) Menu. Scrolling though all rooms is tedious. Need a dedicated/separate button to open Group Menu.
- Native usability gaps… cannot modify the dim level without opening the device. I do set dim often, far more than on only.
- Custom Dashboards… usage and editor is not intuitive. For instance, you can change the config of a widget on the main usage screen but Not in Edit mode? Kinda backwards guys. And, you can add a widget in User mode, but NOT edit mode? Seems like there is a serious rethink needed on Dashboard editing
- List view GUI difficult to use/view since the device rows are so close together. I like an efficient layout but it is too crunched… the level % is difficult to read.
- List view GUI look’n’feel is outdated… on/off buttons, basic black or white background. ‘Cards’ would make separate items easier to follow
- Dashboard GUI look’n’feel is outdated… Material design is needed
- Composite widget … does not support Dim… big miss
- Composite widget … no way to see what devices are in the switch without scrolling through the entire list of all you devices; another huge miss
- Dashboard… no way to hide Android status bar or IH top menu; this would be valuable for dedicated tablets!
- Dashboard Light widgets… the additional on/off buttons are not needed, and redundant. The light bulb icon itself should be used to toggle on/off and show status (which it already does)
- No Weather widget
- Dashboard… no menu of dashboards, while in Dashboard mode. thus, users have no idea what dashboard exist until they scroll left/right through all of them. Not very user friendly
Support:
No dedicated forum for users
No formal feature request method
No way to see reported bug and status from IH (open, fixed, fix eta, etc)
Summary:
- AHD wins as a Daily Driver for my phone.
- IH wins specifically when using the Dashboard feature on a tablet perm in a specific room (in-wall or on table) but not for roaming.
Interested in the larger user bases’ feedback… let me know what I should be looking at to fill the gaps I’m having.
thanks!
