So far i’ve had reasonably good success with bridged Veras. I have a Vera 3 as Primary and a Vera Lite as Secondary.
Right now there are NO Zwave devices installed on the Secondary, only a limited set of APPs. ALL ZWave devices are on the Primary along with some APPs
I will second @AgileHumor’s comment about editing/changing ONLY ON THE VERA WHERE THE DEVICE/APP is installed.
Some specific APPs and my current experience:
EventWatcher **
Works fine on both systems. There does not appear to be any interaction other than replicating the Secondary APP appearance on the Primary. Events and Reports reflect the respective systems. A report run using the Secondary image on the Primary will report on the Primary so you must use the correct system.
Vera Alerts
Works on both systems with a few caveats. The Secondary Vera will send alerts as intended to the Users defined ONLY on the Secondary. With the exception of the principal administrative user, Bridging does NOT transfer/replicate users from the Primary ) >:( ) so you must re-create them or create new ones. (and MCV Tech Support claims they can’t help.)
Everything must be done ONLY on the Vera where the APP is installed. The “appearance” of the Secondary APP on the Primary will show the Profiles and Settings of the Secondary but the “Notification Configuration” will reflect that of the Primary NOT the Secondary.
There does not appear to be a way to manage Secondary alerts from the Primary anyway so if you need SysLog or something for Secondary events (other than those reported by EventViewer) you will have to install Alerts on the Secondary.
MySensors
This works fine on the Secondary and immediately posts results to the Primary. You can in fact run the Inclusion from the Primary but in keeping with the general rule I suggest you only do it from the Vera on which it is physically installed
Day/Night
My results with this were questionable. I moved it to the Secondary and reassigned some Triggers/Properties in a Primary PLEG to use the relocated PlugIn (actually what you use is the “Secondary Image” on the Primary.) I had problems with the PLEG not executing for several days until I relocated the PlugIn back to the Primary so for now I think that Day/Night needs to be installed on the Vera where it is going to be used.
GCal Sensor (NOT the new version, not tested)
This appears to work fine installed on the Secondary and accessed on the Primary. Calendar events detected on the Secondary appear to trigger actions on the Primary without a problem
iPhone Locator
This appears to work fine installed on the Secondary and accessed on the Primary. I have this set up to be used by a Primary PLEG and right now simply update a Primary Virtual Switch with the Present/Away status. (The other three family members have Android devices and are managed by Vera Proximity.)
PingSensor
This appears to work fine installed on the Secondary. The state is reflected on the Primary and you can Arm/Disarm the Secondary from the Primary if you wish. Right now I have several installed monitoring local systems (Blue Iris, SysLog, NetStore, etc) Up/Down reports to SysLog and my phone are handled by the Vera Alert on the Secondary.
[Update **]
I inadvertently wrote EventViewer when I intended EventWatcher.
